Adding, modifying, and removing a custom property
You can add a custom property to a grouping and remove a custom property from the grouping.
- If you remove a custom property, the property is removed from the Properties Browser in the Oracle Central Designer application and is no longer associated with any study objects for which the property value was assigned. Oracle recommends that you do not delete custom properties.
- You must not delete Oracle InForm or Clintrial custom properties, or deployment is likely not to succeed.
- Do not modify Oracle InForm or Clintrial custom properties or groupings.
- You cannot rename custom properties or groupings.
To add a custom property:
- Select System Config.
- In the Customization section, click the Custom
Properties link.
The Custom Properties workspace appears.
- In the Custom Properties list, right-click a grouping, and select
Add Custom Property , or press
Ctrl+N .
A new custom property appears in the Custom Properties list, and details for the custom property appear in the workspace.
- Fill in the fields in the workspace, and click Save.
To modify a custom property:
Properties link.
- Select a custom property.
The custom property appears in the Custom Properties workspace.
- Modify the fields as necessary, and click Save.
To remove a custom property:
- In the Customization section, click the Custom Properties link.
- Right-click a custom property, and select Remove, or press Delete.
- Click Save.
Custom Properties workspace - Field descriptions
The fields that appear in the Custom Properties workspace vary according to what you select. You can select a study object, a grouping, or a custom property.
Field | Description |
A study object is selected. | - |
Groupings |
Name of the grouping for the study object. Groupings organize custom properties in the Oracle Central Designer application. |
A grouping is selected. | - |
Custom Properties | Name of the custom property created under the grouping for a study object. |
A custom property is selected. | - |
Name | Name of the custom property. |
Data Type |
Data type of the custom property:
Max Length | Maximum number of characters allowed for the value of the custom property. |
Description | Description of the custom property. |
Make Property Visible |
Use Value List |
The Use Value List grid has the following fields.
Parent topic: Working with custom properties
