Adding and removing a grouping
You can create a grouping under a study object in the Custom Properties workspace. After you create a grouping, you can add a custom property to the grouping.
- Do not modify InForm or Clintrial custom properties or groupings.
- You cannot rename custom properties or groupings.
To add a grouping:
- Select System Config.
- In the Customization section, click the Custom
Properties link.
The Custom Properties workspace appears.
- Right-click a study object, and select Add
Grouping, or press Ctrl+N, and then type the
name of the grouping.
or
Select a study object, and type the name of the grouping in the blank field in the Groupings grid in the workspace.
- Press Enter.
- Click Save.
To remove a grouping:
Properties link.
- Right-click a grouping, and select Remove, or press Delete.
- Click Save.
Parent topic: Working with custom properties
