Moving, cutting, copying, and pasting a grouping
When you cut or copy and then paste a grouping that contains one or more custom properties, the custom properties are copied or cut and then pasted with the grouping.
To move a grouping:
- Select System Config.
- In the Customization section, click the Custom
Properties link.
The Custom Properties workspace appears.
- Drag a grouping from one study object to the other study object name.
To cut or copy and then paste a grouping:
Properties link.
- Right-click a grouping, and then select either Copy (or press Ctrl+C ) or Cut (or press Ctrl+X).
- Right-click a study object, and select Paste, or
press Ctrl+V.
The grouping is moved.
Parent topic: Working with custom properties
