Conversion calculation XML definition
The definition for a conversion calculation is in the following format:
<UnitConversionMap Name=" name " Classification=" name ">
<UnitConversion From=" name " To=" name ">{value} formula </UnitConversion>
</UnitConversionMap>
XML objects for unit conversion calculations
| XML object | Description |
| UnitConversionMap |
Definition of the type of measurement represented by the unit. Each UnitConversionMap object can include multiple UnitConversion definitions. The UnitConversionMap object has the following attributes:
| UnitConversion |
Formula used to convert one unit value to another. The UnitConversion object has the following attributes:
XML example
<UnitConversionMap Name="Temp" Classification="Temperature">
<UnitConversion From="Cent" To="Fahren">({value}*9/5)+32</UnitConversion>
<UnitConversion From="Fahren" To="Cent">({value}-32)*5/9</UnitConversion>
<UnitConversionMap Name="Weight" Classification="Weight">
<UnitConversion From="Pounds" To="Kilogram">{value}*0.454</UnitConversion>
<UnitConversion From="Kilogram" To="Pounds">{value}*2.205</UnitConversion>
<UnitConversion From="Ounce" To="Gram">{value}*28.35</UnitConversion>
<UnitConversion From="Gram" To="Ounce">{value}/28.35</UnitConversion>
Parent topic: Adding units and conversion calculations
