Previous Topic
Next Topic
Book Contents
Trusted assemblies
The rule sandbox has the following classes of trusted assemblies:
Note: The decision to trust these assemblies is based on a manual procedure of installing certificates in the certificate store. A manual procedure creates the possibility of human error by registering incorrect public keys and establishing trust for a bad assembly.
While trusted assemblies run in the highly restrictive sandbox, they can elevate permissions. For the procedure and guidelines for such elevations, see Elevating CAS permissions.
The only high-level restriction that you can specify at the assembly level is the SecurityTransparentAttribute, which prohibits all elevations in the assembly. If the assembly needs to elevate permissions, the only guards against over-elevating are code review and code analysis tools.
Send Feedback
