Previous Topic
Next Topic
Book Contents
InForm Items Editor—Option descriptions
Columns common to all study object editors
Note: Not all fields appear in the default view. Optionally, you can add the other fields and rearrange the browser view.
Option
Description
Data Label
Text label for the item, enabling access to the item in a target table with the Patient To Control key type or any of the pivot key types.
Display Override
Determines the default behavior of an item when a layout is generated.
  • ReadOnly—The item is visible but not editable.
  • Editable—The item is visible and editable by any user, regardless of the rights assigned to the user.
  • Hidden—The item is not visible.
  • None—The item is visible to all users, and visible and editable by any user who has the rights to view and/or edit the item.
This is a custom property for items deployed in a study in the InForm application.
Item Required
True (default) or False, indicating whether the item is required for data entry on the form to be complete.
MaxProperty
If a MaxValue is specified for the item, indicates whether the value can be less than or less than or equal to the MaxValue.
MaxValue
Maximum value that the InForm application will allow to be typed for the item.
MinProperty
If a MinValue is specified for the item, indicates whether the value can be greater than or greater than or equal to the MinValue.
MinValue
Minimum value that the InForm application will allow to be typed for the item.
PHI
True or False (default), indicating whether an InForm user might enter Personal/Protected Health Information (PHI) for the item.
Question
Default question for the item. This question appears on the form if no customized label or translation is defined for the item. The question can have 0-1000 characters. Certain words may be reserved for this field.
SDV Critical
True or False (default), indicating whether the item is considered critical for source verification. If you select True, SDV Required changes to True.
SDV Required
True (default) or False, indicating whether the item requires source document verification.
ShortQuestion
Text of a short version of the item question. In the InForm application, the short question appears as a column heading in a repeating form, an itemset, and in reports generated by the Reporting and Analysis application. The short question can have 0-255 characters. Certain words may be reserved for this field.
Special Fields
Type of special InForm field, or None, indicating that the item is not a special InForm field. Available special fields, along with the forms in which they appear, are:
  • Initials (Screening).
  • DOB (Screening).
  • Screening date (Screening).
  • Patient No. (Enrollment).
  • Initials (Patient Identification.
  • Completion status (Study Completion).
  • Drop-out reason (Study Completion).
  • DOV (Date of Visit).
  • Randomization field (Randomization).
Type
Item type; one of the following, or a custom item type defined in a library to which the study has access:
  • Blood pressure
  • Compound
  • Date time
  • Float
  • Integer
  • Text
  • Yes No
Note: To type extended ASCII characters in text fields, press ALT while entering the decimal code for the character. You can also add HTML formatting characters to a text field to control its appearance when deployed.
Send Feedback
