Previous Topic
Next Topic
Book Contents
General tab of the Form Editor or Section Editor—Option descriptions
Option
Description
Settings section
Title
Title of the form or section. The title can have 1-63 characters.
Short Title (Form Editor only)
Short title of the form. The short title is deployed to the InForm application as the form mnemonic. The short title can have 1-63 characters.
RefName
RefName of the form or section. The RefName can have 1-63 characters.
Description
Description of the form or section. The description can have 0-255 characters.
Behavior section
Repeating
Indicates that the form or section is repeating. Multiple instances of the same set of data appear in the form or section.
Common (Form Editor only)
Indicates that the form is common. The same data is visible in all study events that contain the form.
Short Title Languages section (Form Editor only)
Language
Language and locale to which the short title is translated.
Short Title
Translated text of the short title. The short title can have 1-63 characters.
Note: To type extended ASCII characters in text fields, press ALT while entering the decimal code for the character. You can also add HTML formatting characters to a text field to control its appearance when deployed.
Send Feedback
