Previous Topic
Next Topic
Book Contents
Import Wizard options - CSML or ODM file
Pages in the import wizard for CSML or ODM files
Page
Option
Description
Welcome
Introduction page.
Import Type
Select the source of the data to import.
Import CSML or ODM file
Generate study objects from a file in CSML or ODM format.
Harvest InForm Resources
Generate study objects from the components of an InForm study.
File Location
Path of file to import
Specify the path of the CSML or ODM import file, or click Browse to locate the import file.
Study Administration Import Mode
This page appears only for the CSML import type, if the CSML file contains study administration objects.
Import study objects and administration data.
Import both study objects and study administration objects.
Import administration data only.
Import only study administration objects.
Import study objects only.
Import only study objects.
Rule Import Mode
Rule Import Mode
Only the Import as Collaboration Notes option is supported. With this option, each imported rule is converted to a collaboration note in the Central Designer application.
Note: This option applies only if the Import Type is ODM; if the Import Type is CSML, the import process creates a Central Designer rule for each imported rule.
IPR Import Mode
Import IPR data
Select whether to import in-place revision objects.
Note: This page appears only if the file contains in-place revision objects.
Ready to Import Data to Central Designer
View a summary of the import options selected in the wizard.
Send Feedback
