Previous Topic
Next Topic
Book Contents
Export Wizard options
Pages in the Export Wizard
Page
Option
Description
Welcome
Introduction page.
Export Type
Select the output format and export type.
Data Type
CSML—Export in Clinical Study Markup Language format.
ODM—Export in Operational Data Model-compliant format. The Central Designer application supports the ODM 1.3 standard.
Administration data—Export only study administration data for the User Management Tool application.
Export Type
Local—Export to the computer where the Central Designer application is installed.
Export File Path
Export Directory
Specify the path name and file in which to save the export file, or click Browse to browse for the path name and file in which to save the export file.
Ready to Export Central Designer Data
View a summary of the parameters that will be used for the export.
Send Feedback
