Translation file requirements
- Do not change any values in the translation file except the strings in the LocaleToTranslate position (last field in each record).
- The header record must be present.
- Each record must conform to the following standards:
- All records must have the same number of fields.
- RefName and Id fields must not be empty.
- RefName length must be less than or equal to 63 characters.
- Revision and OwnerType lengths must be less than or equal to 255 characters.
- ReferenceLocaleValue and LocaleToTranslate lengths must be less than or equal to 32000 characters.
- Double quotation marks (") are required for any field that contains a line break, double quote, or comma and are optional for any other field.
- If a field contains a double quotation mark character [for example, Dizzy ("Groggy")], you must include another double quotation mark as an escape character, as follows: "Dizzy (""Groggy"")"
- Lines must end with a Windows-style (CRLF) line terminator.
