Translation file format
The translation export and import CSV file consists of a header and translation records in the following formats.
Header
The header contains the following values: RefName,OwnerType,SrType, Id,Revision,
<ReferenceLocaleValue>,< LocaleToTranslate>
- <ReferenceLocaleValue>—Locale of the strings from which to translate, as specified in the Locale to translate from field of the Export Translations dialog box. Example: en-US.
- <LocaleToTranslate >—Locale to which text strings are being translated, as specified in the Locale to translate field of the Export Translations dialog box. Example: fr-FR.
Example of file header
RefName,OwnerType,SrType,Id,Revision,en-US,fr-FR
Records
Each translation record contains the following fields: <RefName>,<OwnerType>,<SrType, <Id>,<Revision>,<ReferenceLocaleValue>,< LocaleToTranslate>, as described in the following table.
Format of translation file records
Field |
Description |
RefName |
RefName of the study object that owns the string.
OwnerType |
Internal type of the study object that owns the string resource. |
SrType |
Internal type of the field that references the string resource. |
Id |
GUID of the string resource in CSML. |
Revision |
Revision number of the study object for which the text string is defined. |
ReferenceLocaleValue |
Text string in the locale to translate. |
LocaleToTranslate |
Translated text string. This value is empty when you export the file. The translator fills in the value before you import the file. Note: The LocaleToTranslate is the only value that may be changed in each record. |
Examples of file records
Layout_5fxx,LayoutPlan,ItemCaption,d067b170-8885-11e1-b0c4-0800200c9a66,12, "DOV Form","Forme pour la date de visite"
Itm_DOB,DateTime,Question,26beca46-663e-4841-ab8b-03ff6b7a78f9,5,"Date of Birth","Date de naissance"
