Create Deployment Package Wizard—Full deployment package
Page |
Option |
Description |
Welcome |
Introduction page. |
Select a Deployment Package Type |
Specify the type of deployment package to create. Note: To deactivate a rule in the InForm application, do one of the following in the Central Designer application before creating a new deployment package:
Rule-related changes that you make in the InForm application are overridden when you install a new deployment package. Note: If you create or modify a coding map, use a full deployment package to deploy the changes. Changes to coding maps are not supported in incremental deployment packages. |
Full package |
Deployment package that contains everything needed to deploy a complete study. |
Incremental package |
Deployment package that contains everything needed to deploy a complete study, plus additions and changes to the study, reflected in Alternate forms in the InForm application. Alternate forms are not created when you install an incremental deployment package that contains additions to repeating forms or fixed repeating sections (Repeating Data itemsets in the InForm application). |
Administration data |
Deployment package that contains only study administration data. |
Custom events |
Deployment package that contains one or more in-place revisions on custom events. Note: The Custom Events option is for updating existing events. You cannot use it to add a new custom event to a study. |
Select a Baseline |
Specify the baseline to use for creating the deployment package. Validation baselines with a status of Valid or Valid with Warnings are eligible. Note: If you select an unpublished validation baseline, the baseline is made public during deployment package creation. |
Please select a baseline |
Drop-down list of validated baselines available for creating a deployment package. |
In-Place Revisions |
If the specified baseline contains in-place revisions, review the changes and confirm you understand the risks of deploying before proceeding. |
View IPR Summary |
Open the IPR Summary dialog box to review the revisions included in the baseline. |
Confirmation text |
Select the checkbox to confirm that you understand the risks involved in deploying to the InForm application. Select the checkbox to confirm that you understand the risks involved in deploying to the InForm application. |
Select Locales |
Specify the locale or locales for which to create the deployment package. You must select at least one locale. Note: Each option is applicable for different releases of the InForm application, and only one option is used for each release. However, you must select values for both options. |
Please select one or more locales |
List of locales available to be supported by the deployment package. Note: This option is used when you deploy to InForm release 4.6. |
Apply layout from |
Specify the default layout locale for the deployment package. In InForm release 4.7 and later, a single study version contains the layout information for all locales in the study, and you specify a default layout locale, from which all layouts, regardless of locale, inherit customizations in the InForm application. The site locale language in the InForm application determines the language in which forms appear. For example, a study contains layouts for the French (France) and the English (United Kingdom) locales. Radio buttons are horizontal in the French (France) layout but are vertical in the England (United Kingdom) layout. If French (France) is the default layout locale, then all layout customizations for the France (French) layout, including the alignment of radio buttons, are deployed to the InForm application and appear for all users, regardless of their site locale. Therefore, if your site locale in the InForm application is English (United Kingdom), the forms appear in English but with the customizations that were made in the French (France) layout in the Central Designer application. Note: This option is used when you deploy to InForm release 4.7 and later. |
Select Layouts |
Choose the layout to deploy. If the layout does not exist for a form, the primary layout for the form is deployed instead. The list contains only the registered layout names in the study, which appear in the Tools > Layout Names Manager dialog box. |
Select Customer Defined Database (CDD) Mappings (optional) |
Specify the mappings used to generate mappings for a CDD. This page appears only if at least one CDD mapping is defined for the study. Only CDD mappings appear in the list. |
Optionally, select one or more mappings for CDD mapping |
List of CDD mappings. Tip: If you are deploying a study version change, and the study version includes new visits with items used in mappings, you must include the mappings when you create the deployment package. |
Select All |
Select all mappings in the list. |
Unselect All |
Deselect all mappings in the list. |
Select Clintrial Integration Solution (CIS) Mappings (optional) |
Specify the mappings used to generate mappings for the CIS application. This page appears only if at least one CIS mapping is defined for the study. Only CIS mappings appear in the list. |
Optionally, select one or more mappings for CIS mapping |
List of CIS mappings. Tip: If you are deploying a study version change, and the study version includes new visits with items used in mappings, you must include the mappings when you create the deployment package. |
Select All |
Unselect All |
Specify a Name and Description |
Specify a name and description for the deployment package. |
Please specify a name for your deployment package |
Name of the deployment package. |
Package description |
Description of the deployment package. |
Apply new study version to all sites |
Select to apply the study to all sites. |
Email dropbox location |
Specify the location to which to send an email triggered by a rule. |
MedML Files (optional) |
Attach MedML files to the deployment package. The order in which the files are deployed is determined by their order in the grid. Note. The MedML files are validated by the InForm application prior to execution. |
Add |
Add a MedML file to the grid. |
Remove |
Remove selected MedML file from the grid. |
Move Up |
Move selected file higher in the grid. |
Move Down |
Move selected file lower in the grid. |
Select All |
Select all files in the grid. |
Ready to Create Deployment Package |
View a summary of the deployment options selected in the wizard. |
Options summary |
Summary of options selected for the deployment package. |
