Create Deployment Package Wizard—Incremental deployment package
Page |
Option |
Description |
Welcome |
Introduction page. |
Select a Deployment Package Type |
Specify the type of deployment package to create. Note: To deactivate a rule in the InForm application, do one of the following in the Central Designer application before creating a new deployment package:
Rule-related changes that you make in the InForm application are overridden when you install a new deployment package. Note: If you create or modify a coding map, use a full deployment package to deploy the changes. Changes to coding maps are not supported in incremental deployment packages. |
Full package |
Deployment package that contains everything needed to deploy a complete study. |
Incremental package |
Deployment package that contains everything needed to deploy a complete study, plus additions and changes to the study, reflected in Alternate forms in the InForm application. Alternate forms are not created when you install an incremental deployment package that contains additions to repeating forms or fixed repeating sections (Repeating Data itemsets in the InForm application). |
Administration data |
Deployment package that contains only study administration data. |
Custom events |
Deployment package that contains one or more in-place revisions on custom events. Note: The Custom Events option is for updating existing events. You cannot use it to add a new custom event to a study. |
Select a Previously Created Deployment Package |
Specify the previously created deployment package for which this is an incremental package. |
Please select a deployment package |
Drop-down list of previously created deployment packages. |
Select a Baseline |
Specify the validation baseline to use for creating the incremental deployment package. This baseline must have a date and time that is later than the validation baseline used to create the deployment package selected on the previous page. |
Name of the deployment package selected on the previous page. |
Package Baseline |
Validation baseline used to create the selected deployment package. |
Please select a baseline for the incremental package |
Drop-down list of validated baselines available for creating the incremental deployment package. |
In-Place Revisions |
If the specified baseline contains in-place revisions, review the changes and confirm you understand the risks of deploying before proceeding. |
View IPR Summary |
Open the IPR Summary dialog box to review the revisions included in the baseline. |
Confirmation text |
Select the checkbox to confirm that you understand the risks involved in deploying to the InForm application. |
Add Locales (Optional) |
Specify the additional locale or locales for which to create the incremental deployment package. This page appears only if you have added new locales to the validation baseline. |
Optionally, select one or more locales |
List of locales available to be supported by the deployment package. |
Select All |
Select all locales in the list. |
Unselect All |
Deselect all locales in the list. |
Add Customer Defined Database (CDD) Mappings (Optional) |
Specify the additional mapping or mappings, if any, to use in the incremental package for generation of CDD mappings. This page appears only if you have added new CDD mappings to the validation baseline. If you have made changes to existing CDD mappings, those mappings are used in the deployment package to update the CDD mappings. |
Optionally, select one or more CDD mappings |
List of CDD mappings. Tip: If you are deploying a study version change, and the study version includes new visits with items used in mappings, you must include the mappings when you create the deployment package. |
Select All |
Select all mappings in the list. |
Unselect All |
Deselect all mappings in the list. |
Add Clintrial Integration Solution (CIS) Mappings (Optional) |
Specify the additional mapping or mappings, if any, to use in the incremental package for generation of CIS mappings. This page appears only if you have added new CIS mappings to the validation baseline. If you have made changes to existing CIS mappings, those mappings are used in the deployment package to update the CIS mappings. |
Optionally, select one or more CIS mappings |
List of CIS mappings. Tip: If you are deploying a study version change, and the study version includes new visits with items used in mappings, you must include the mappings when you create the deployment package. |
Select All |
Unselect All |
Specify a Name and Description |
Specify a name and description for the incremental deployment package |
Please specify a name for your deployment package |
Name of the incremental deployment package. |
Package description |
Description of the incremental deployment package. |
Apply new study version to all sites |
Select to apply the study to all sites. |
Email dropbox location |
Specify the location to which to send an email triggered by a rule. |
MedML Files (optional) |
Attach MedML files to the deployment package. The order in which the files are deployed is determined by their order in the grid. Note. The MedML files are validated by the InForm application prior to execution. |
Add |
Add a MedML file to the grid. |
Remove |
Remove selected MedML file from the grid. |
Move Up |
Move selected file higher in the grid. |
Move Down |
Move selected file lower in the grid. |
Select All |
Select all files in the grid. |
Ready to Create Deployment Package |
View a summary of the deployment options selected in the wizard. |
Options summary |
Summary of options selected for the incremental deployment package. |
