Step 1: Create a drop-down list or set of radio buttons or checkboxes (a codelist with codelist items)
- At the bottom of the Project Explorer, click the Items (
) button, and expand the InForm Items folder. - On the Design tab, in the Codelist Settings section, select one of the following:
- Select Single Value—Allow users to select only one option in the list of codelist items.
- Select Multiple Values—Allow users to select more than one option in the list of codelist items. If you select this option, you must also enter the minimum and maximum number of checkboxes the user can select.
- At the top of the page, select the Layout tab.
- If you haven't already done so, click Create Layout.
- On the right of the page, right-click the codelist that you just created, select Control Type, and indicate whether you want to create a set of options in a drop-down list, radio buttons, or checkboxes.
