Previous Topic
Next Topic
Book Contents
Step 2: Define sets of drop-down list options, radio buttons, or checkboxes (codelist subsets)
  1. At the bottom of the Project Explorer, click the Codelists (Codelists) button.
  2. In the Project Explorer, expand the Codelists folder, and select the codelist you created in Step 1.
  3. At the top of the page, select the Subsets tab.
  4. Do one of the following:
    • To copy an existing subset, in the top half of the page, select the subset, and click Replicate.
    • To create a new subset:
      1. In the top half of the page, click in the last row.
      2. Enter a description for the subset, and press Enter or Tab to save the changes.
      3. Highlight the row.
      4. At the bottom right, click Add.
      5. Select the codelist items to add to the subset, and click OK.
      6. On the bottom right of the page, use the Move Up and Move Down buttons to configure the order of the codelist items in the subset.
Send Feedback
