Previous Topic
Next Topic
Book Contents
Create a Clintrial enrollment panel
  1. Create a data set for the enrollment panel.
    Note: Master-detail relationships are not supported in enrollment panels. If the Detail Key Item, Detail Panel, Master Item, or Master Panel CIS custom properties have values in the data set for an enrollment panel, validation fails.
  2. On the Properties tab, set the value of the Panel Type CIS custom property to Enrollment, and press Enter.
    Tip Tip: If you don't see the Properties tab, at the top left of the page, select View, and make sure Properties is selected.
  3. Create a data series for each screening or enrollment item to include in the panel. (Clintrial does not have a separate panel for screening and enrollment data.)
  4. Add items to the data series.
Send Feedback
