Previous Topic
Next Topic
Book Contents
Create a non-patient data (Type 0) panel
  1. Create a data set for the non-patient data panel.
    Note: Master-detail relationships are not supported in non-patient data panels. If the Detail Key Item, Detail Panel, Master Item, or Master Panel CIS custom properties have values in the data set for a non-patient data panel, validation fails.
  2. On the Properties tab, set the value of the Panel Type CIS custom property to Non-Patient Data, and press Enter.
    Tip Tip: If you don't see the Properties tab, at the top left of the page, select View, and make sure Properties is selected.
  3. Create a data series for each item to include in the panel.
    Note: Do not map items to any of the data series in the panel.
Send Feedback
