Previous Topic
Next Topic
Book Contents
What is the format of the translation export and import CSV file?
The translation export and import CSV file consists of a header and translation records in the following formats.
Header
The header contains the following values: RefName,OwnerType,SrType, Id,Revision,
<ReferenceLocaleValue>,< LocaleToTranslate>
Example of file header
RefName,OwnerType,SrType,Id,Revision,en-US,fr-FR
Records
Each translation record contains the following fields: <RefName>,<OwnerType>,<SrType, <Id>,<Revision>,<ReferenceLocaleValue>,< LocaleToTranslate>, as described in the following table.
Format of translation file records
Field
Description
RefName
RefName of the study object that owns the string.
OwnerType
Internal type of the study object that owns the string resource.
SrType
Internal type of the field that references the string resource.
Id
GUID of the string resource in CSML.
Revision
Revision number of the study object for which the text string is defined.
Text string in the locale to translate.
LocaleToTranslate
Translated text string. This value is empty when you export the file. The translator fills in the value before you import the file.
Note: The LocaleToTranslate is the only value that may be changed in each record.
Examples of file records
Layout_5fxx,LayoutPlan,ItemCaption,d067b170-8885-11e1-b0c4-0800200c9a66,12, "DOV Form","Forme pour la date de visite"
Itm_DOB,DateTime,Question,26beca46-663e-4841-ab8b-03ff6b7a78f9,5,"Date of Birth","Date de naissance"
Send Feedback
