Previous Topic
Next Topic
Book Contents
What does a translator do with the exported text strings for translation?
After the text strings for a study or library are exported, a translator adds translated strings to the exported file and saves the file.
Note: If you use Microsoft Excel spreadsheet software as the CSV file editor, you must import the exported file as Unicode UTF-8; you cannot simply open the file and edit it. Additionally, you must export the edited file as Unicode UTF-8 CSV; you cannot save it and preserve the correct formatting. You might want to develop a Microsoft Excel macro specification or other tool that performs this processing. For guidance, see the Microsoft Excel documentation.
Translation file format
Translation file requirements
Send Feedback
