Previous Topic
Next Topic
Book Contents
How are Partial SDV default values affected by a migration or upgrade?
Central Designer is designed so that the behavior defined for Partial SDV does not change when you migrate or upgrade from a version of Central Designer prior to version 6.3. In Central Designer 6.3.x, you now have the ability to update Partial SDV settings for InForm sites globally within Central Designer.
Send Feedback
