(Optional) Design other forms that may contain data to send to Argus along with the Adverse Event form
Once you have created the Adverse Event form, you have the option to create other forms to send historical or clinical data to Argus as part of a case (for example, medical history, concomitant medications, lab test results).
When designing other forms that may contain data to send to Argus along with the Adverse Event form, consider that:
- When you design control captions that will be used in a dynamic grid (for example, for an item question or codelist label), make sure that they are fully labeled so that the data makes sense in the dynamic grid.
- If an in-place revision includes a form or section used as a source form for a dynamic grid section, you must apply the same in-place revision to the dynamic grid section.
To design other forms:
- At the bottom of the Project Explorer, click the Visit Schedule (
) button. - Right-click the study event to which you want to add the form to, select New, and select Form.
- Enter a Title, RefName, and Description, and click OK.
- In the Project Explorer, select the new form, and make sure the Design tab is selected.
- If you want this to be a repeating form, in the upper-right above the grid, check the Repeating checkbox.
- If you want this to be a flat form with a repeating section:
- Uncheck or keep unchecked the Repeating checkbox.
- Expand the visit with the related form you want to add the section to, right-click the form, and select New Section.
- Make sure the Design tab is selected.
- In the upper-right above the grid, select the Repeating checkbox.
- If you want this a flat form with a fixed, repeating section so you can send data the user doesn't enter:
- In the upper-right above the grid, select the Fixed and Repeating checkboxes:
- Create fixed items in the section.
- For each item that you want to define as a fixed item:
- In the grid, add items.
