Supported changes with study version changes
The following study version changes are supported for dynamic grids after deploying your study:
- Adding a new dynamic grid.
- Adding a target item to an existing dynamic grid.
- Adding a new editable item to an existing dynamic grid.
- Adding a new source to an existing dynamic grid.
- Removing a source item previously mapped to an existing dynamic grid.
- Removing a target item from an existing dynamic grid.
- Removing an editable item from a dynamic grid.
- Removing a source from an existing multi-source dynamic grid.
- Removing a dynamic grid section.
Note: Removing a dynamic grid section is not supported for InForm to Argus integration because removing the safety logical schema mappings is not study-version specific.
- Changing the source item properties (such as label, question or control) on an item previously mapped to an existing dynamic grid.
- Changing the target item properties (such as label, question or control) on an item previously mapped to an existing dynamic grid.
- Changing the editable item properties (such as label, question or control) on an item previously mapped to an existing dynamic grid.
Note: Although you can do in-place revisions and study version changes to add sources to dynamic grid, the InForm to Argus integration does not support changing it from single-source to multi-source. The reason for this is that the InForm to Argus integration requires safety mappings, which are not version specific.
