Supported changes with in-place revision changes
The following in-place revision changes are supported for dynamic grids after deploying your study:
- Adding mapped items to target on an existing dynamic grid.
- Adding an item to a source and map it to an existing dynamic grid.
- Adding a new editable item to an existing dynamic grid.
- Adding a new source to an existing dynamic grid.
- Removing mapped items from a target on an existing dynamic grid.
- Removing a source from an existing multi-source dynamic grid.
Note: In-place revisions to remove a source will not result in data loss in the Inform user interface, and data sync will still occur until any existing links between the source are the target are broken.
- Changing the source item properties (such as label, question, or control) on an item previously mapped to an existing dynamic grid.
- Change the target item properties (such as label, question, or control) on an item previously mapped to an existing dynamic grid that is not shared with the source.
- Change editable item properties (such as label, question, or control) on an item previously mapped to an existing dynamic grid.
Note: Although you can do in-place revisions to add sources to dynamic grid, the InForm to Argus integration does not support changing it from single-source to multi-source. The reason for this is that the InForm to Argus integration requires safety mappings, which are not version specific.
