Settings tab of the CIS Synchronization Adapter page—Fields
Field |
Description |
Number of transactions per message |
Number of transactions in a message. The number of transactions per message is the number of transactions per operation, including the sending and receiving of transactions between InForm Adapters and Clintrial Adapters. In general, the more transactions per message, the faster the synchronization completes because fewer requests are made to the adapters. However, when typing a value for this option, you should consider that all transactions in each operation are in memory. Therefore, if you have a number of synchronizations running, a high number of transactions per operation could result in a greater demand on memory. Oracle recommends that you accept the default value of 500 for this option. A lower value might slow down a synchronization. |
Load balancing timeout (seconds) |
Number of seconds for CIS to wait before setting a load-balancing machine on which synchronization has stopped to offline. |
Email server |
Fully-qualified domain name of the email server being used to send notifications, for example, smtp.company.com. |
From email |
Email address that will be used as the From address in email notifications. Note: The address you specify must be a valid email address that has been defined in your email system. The CIS Administration does not prevent you from entering and saving an email address that contains spaces and might not be treated as a single entity. To specify an email address that contains spaces, enclose the email address in double quotes. |
Email source link |
Web link to the CIS administration login page in the body of the email message. |
Sync user name |
User name for the CIS Administration user. Note: The Sync user name is the Service user. |
Sync user password |
Password for the CIS Administration user Important: Although you can change the Sync user password in this page, you must first change the password for the Service user in the Profile tab of the Security Administration Edit User page. For more information, see Editing a user profile. Then you can make changes in this page. |
