General tab of CIS Synchronization Connection page—Fields
Field |
Description |
Sync name |
Synchronization connection name entered when the synchronization connection was created. |
CIS Metadata Locale |
Specifies the language to use when synchronizing the trial. |
Clintrial |
Clintrial information about the synchronization connection definition. |
Machine |
URL of the Clintrial Adapter. |
Instance |
Clintrial database instance for the synchronization. |
Protocol |
Clintrial protocol to which the synchronization connection transfers data. |
Metadata Only |
Auto-generate Codelist |
InForm |
InForm information about the synchronization connection definition. |
Machine |
URL of the location of the InForm Adapter. |
Trial |
Name of the InForm trial. |
Mapping |
Name of the mapping definition used for the synchronization. |
