Field
Description
Sync name
Synchronization connection name entered when the synchronization connection was created.
Choose new mapping option
- Assume no data—If mapping definitions for data items for which no mappings originally existed are synchronize later, the CIS software continues to ignore the previously unmapped data. For those data items, the CIS software processes only data that arrives subsequent to the mapping definitions.
- Replay transactions—When a new mapping definition arrives, the CIS software replays all transactions that contain the control path in the new mapping. If the CIS software finds any new mappings, it inserts the data in the appropriate Clintrial database column.
Temporarily apply to continuous mappings?
Start sync?
- Yes—Start the synchronization immediately.
- No—Do not start the synchronization immediately. When this option is selected, the synchronization either runs when scheduled or if a user manually runs the synchronization.
