Overview of managing adapters
You can view adapter information from CIS central administration. When only a single adapter of a specific type is registered, the Admin Adapter page for that specific adapter appears initially. When multiple adapters of the same type are configured and registered, information about these adapters in your CIS environment appear in the Adapter List page. From Adapter List page, you can change the view between a list of Adapters or End Points, view only enabled adapters, and change the refresh rate for the page. You can also access other pages to view and manage adapters. The Adapter List page provides summary information for each adapter. From this page, you click a row to view details about that specific adapter.
For more information, seeAdapter List page - Fields.
Field
Description
View
- Adapters—The page displays a list of adapters.
- End Points—The page displays the list of InForm trials that are associated with an InForm Adapter.
Enabled Only
- If selected—The list of adapters shows only adapters for which the status is Enabled.
- If not selected—The list of adapters shows all registered adapters.
Auto-refresh
- If selected—The page refreshes automatically at the interval specified on the Settings tab of the My CIS page.
- If not selected—The page does not refresh automatically.
Adapter
Name of the adapter.
Classification
Information about the product type, the adapter type, and the adapter version.
Ping status
- Green check mark—CIS Administration can communicate with the adapter.
- Red X—CIS Administration cannot communicate with the adapter.
Adapter status
- Green check mark—Adapter status is OK.
- Red X—Adapter status is Error.
- Gray circle with a line—Adapter is disabled.
Enabled status
- Yes—Adapter is enabled.
- No—Adapter is disabled.
From the Adapter List page, you can:
