Filtering and sorting adapters in the adapter list
From the Adapter List page, you can filter the adapters that appear in the list and sort the adapter list by column.
- To view just enabled adapters, select Enabled Only.
Only enabled adapters appear in the list.
- To view all registered adapters, deselect Enabled Only.
All adapters registered appear in the list.
- To sort the columns in a table, click on the specific column.
