CIS Synchronization Connection Wizard—Schedule page—Fields
Note: When specifying a schedule for synchronization connections, make sure that you don't schedule more than one initial synchronization to run at the same time. Doing so causes a failure.
Field |
Description |
None |
The synchronization connection does not use a schedule. Note: If you do not define a schedule, you must manually run synchronization on the synchronization connection. For more information, see Starting a synchronization manually. |
Named |
The synchronization connection uses the schedule selected from the drop-down list. |
Custom |
The synchronization connection uses the custom schedule defined in the Days, Start time (UTC), End Time (UTC), and Run every fields. |
Days |
Days of the week to which the custom schedule applies. Select each day on which to run synchronization. |
Start time (UTC) |
Time for synchronization to begin running. Specify the time in hours and minutes. |
End time (UTC) |
Time for synchronization to stop. Specify the time in hours and minutes. |
Run every |
Interval on which to start synchronization within the specified Start time (UTC) and End time (UTC). For example, if you have a Start Time of 1:00 and an interval of 5 Minutes, the scheduled synchronization begins at 1:00, 1:05, 1:10, and so on. Type a number, and select Hours or Minutes. |
