Field
Description
Clintrial protocol
Clintrial protocol that is the target of the synchronization connection:
- Existing protocol—Indicates that the synchronization connection connects to the Clintrial protocol selected in the drop-down list.
- New protocol—Indicates that the synchronization creates and updates the Clintrial protocol specified in the text field.
Note: The value specified in this field becomes the name of an Oracle user. Therefore, the new protocol name must meet Oracle requirements for user names.
Note: The protocol name you specify must adhere to the following rules for naming Clintrial. software objects:
- Name cannot exceed 20 characters.
- First character must be alphabetic.
- Alphabetic and numeric characters are allowed.
- Do not use any special characters, except the underscore (_).
- Do not use Clintrial software reserved words. For more information, see the Clintrial Reference Guide.
New mappings
Specifies how the synchronization connection processes new mapping definitions:
- Assume no pre-existing data—If mapping definitions for data items for which no mappings originally existed are synchronize later, the CIS software continues to ignore the previously unmapped data. For those data items, the CIS software processes only data that arrives subsequent to the mapping definitions.
- Replay sync to gather pre-existing data—When a new mapping definition arrives, the CIS software replays all transactions that contain the control path in the new mapping. If the CIS software finds any new mappings, it inserts the data in the appropriate Clintrial database column.
- Stop sync for intervention—When a new mapping definition arrives, the CIS software stops the message queue and waits for a manual intervention.
Auto-create study books
- Yes—CIS creates study books for the Clintrial protocol, including page templates and page sections, by using the study component definitions synchronized from InForm software.
- No—CIS does not create study books for the Clintrial protocol.
For more information, see Autocreating Clintrial study books.
Create panels and items
- Yes (default)—CIS creates or modifies Clintrial panels and items as defined in the mappings.
- No—CIS does not create or modify Clintrial panels and items.
For more information, see Autocreating Clintrial panels and items.
