CIS Synchronization Connection Wizard—Clintrial Instance page—Fields
Field |
Description |
Instance |
Name of the Clintrial database instance. |
CISUSER password |
Password for the CISUSER user in the database instance. |
Get State Options |
Click to populate the State to map queries as open list box. |
State to map queries as open |
Clintrial discrepancy status that corresponds to the InForm Open query status. There is no default; you must specify a value. This information is used for transfer of query (discrepancy) information from the Clintrial database back to the InForm database. If the value you specify for "State to map queries as open" matches the value in the Clintrial software for "Discrepancy initial status" for the Clintrial rule, the Clintrial discrepancy maps as an Open query in the InForm software. If the values do not match, the Clintrial discrepancy maps as a Candidate query in the InForm software. Note: If in the Clintrial software the value for "Discrepancy initial status" of a Clintrial rule is not specified, the CIS software assumes the default value "Ready to Send". |
