CIS Synchronization Connection Wizard—Connection Settings page—Fields
Field |
Description |
Sync name |
Name of the synchronization connection. |
Sync description |
Description of the synchronization connection. |
Enabled |
Note: If a synchronization is disabled, you can start the synchronization manually by clicking Sync Now on the Sync Connections tab of the CIS Synchronization Adapter page. |
CIS Metadata Locale |
Specifies the language to use when synchronizing the trial. |
InForm Metadata only |
Auto-generate codelist |
Indicates whether CIS automatically generates Clintrial codelists when synchronizing metadata that includes radio and pulldown controls from InForm software:
Number of transactions per message |
Number of transactions in a message. The number of transactions per message is the number of transactions per operation, including the sending and receiving of transactions between InForm Adapters and Clintrial Adapters. In general, the more transactions per message, the faster the synchronization completes because fewer requests are made to the adapters. However, when typing a value for this option, you should consider that all transactions in each operation are in memory. Therefore, if you have a number of synchronizations running, a high number of transactions per operation could result in a greater demand on memory. Oracle recommends that you accept the default value of 500 for this option. A lower value might slow down a synchronization. |
