Reviewing and saving a new connection
After you provide information for the synchronization connection, use the Summary page to review the information about the synchronization connection. If you want to make changes, you can navigate to previous pages to make changes, or you can save the synchronization connection.
- If the synchronization connection is not correct, click Previous to return to a page to make corrections and then use Next to return to the summary page.
- When the synchronization connection is correct, click Finish to save it.
The Synchronization connection created successfully summary page appears. From this summary page, you can:
