Specifying a schedule
For the synchronization connection, you can select an existing named schedule, create a custom schedule, or not schedule the synchronization. If you do not define a schedule for the synchronization connection, you must manually run the synchronization. For more information, see Starting a synchronization manually.
To select a schedule or define a new schedule for a synchronization connection:
- Select the type of schedule that you want for the synchronization connection.
Note: When specifying a schedule for synchronization connections, make sure that you don't schedule more than one initial synchronization to run at the same time. Doing so causes a failure.
- Complete the fields on the page, and click Next.
The CIS Synchronization Connection Wizard - Summary wizard page appears.
CIS Synchronization Connection Wizard - Schedule page - Fields.
Field
Description
None
The synchronization connection does not use a schedule.
Note: If you do not define a schedule, you must manually run synchronization on the synchronization connection. For more information, see Starting synchronization manually.
Named
The synchronization connection uses the schedule selected from the drop-down list.
Custom
The synchronization connection uses the custom schedule defined in the Days, Start time (UTC), End Time (UTC), and Run every fields.
Days
Days of the week to which the custom schedule applies. Select each day on which to run synchronization.
Start time (UTC)
Time for synchronization to begin running. Specify the time in hours and minutes.
End time (UTC)
Time for synchronization to stop. Specify the time in hours and minutes.
Run every
Interval on which to start synchronization within the specified Start time (UTC) and End time (UTC). For example, if you have a Start Time of 1:00 and an interval of 5 Minutes, the scheduled synchronization begins at 1:00, 1:05, 1:10, and so on.
Type a number, and select Hours or Minutes.
