Selecting an InForm trial
- From the InForm machine drop-down list, select the computer where the InForm Adapter is registered.
The CIS software populates the InForm trial drop-down list when you select a machine.
Note: If only one Adapter is registered, this drop-down list does not appear.
- From the InForm trial drop-down list, select the InForm software trial for the synchronization connection.
The CIS software populates the Mapping drop-down list with the names of the mapping definitions that exist for the selected trial.
- From the Mapping drop-down list, select the mapping definition to use when synchronizing data for the trial.
- Click Next.
The CIS Synchronization Connection Wizard - Schedule page appears.
