Overview of changing global synchronization connection settings
You use the Settings tab of the CIS Synchronization Adapter page to view and change the values for all synchronization connection settings.
From the Settings tab, you can set values for the following:
- Number of transactions to send per message during a synchronization. The default value comes from the installation. Changing this value applies only to new synchronizations that you create. Existing synchronizations are not affected by this change.
- The timeout period for load balancing. The default value comes from the installation.
- The email server to use to email notifications when a synchronization failure occurs. This field has no default value. You must set this value for email notifications. For more information, see Managing email notifications.
- The email address that appears in the From field of the email notification.
- The text that appears in the Subject field of the email notification.
- The password for the Sync user.
Note: Changing the password here does not actually change the password of this user. You must also make the change in the Profile tab of the CIS Administration Edit User page. For more information, see Editing a user profile.
