Viewing and editing transactions
You can edit the transaction that caused the last synchronization to fail from the Status tab of the CIS Synchronization page.
Caution: Oracle recommends that you edit transactions only when no other option is available. You should also have a well-documented process that meets good clinical practice guidelines when you edit a transaction. Editing a transaction will make the Clintrial data different from the InForm data.
- Select Admin > CIS Sync.
- Click the row of the synchronization connection you want to view.
The Status tab of the CIS Synchronization Connection page appears.
- Click View Error.
The Error Detail view appears.
- Click Edit Transaction.
The Synchronization Connection Transaction Edit screen of the CIS Synchronizations Status tab appears.
- In the text box, locate the GUID of the transaction that caused the error in the last synchronization and correct the transaction.
- In the Reason for edit field, type the reason for correcting the transaction and the corrections made.
- Click Validate to validate the transaction.
- Click Save.
