Managing new mappings
If a synchronization connection has Stop sync for intervention selected, the New Mapping Options button is enabled when a synchronization fails because the CIS software has encountered new mappings. Use this button to specify how the new mappings should be processed.
To manage mapping options for the synchronization job:
- Select Admin > CIS Sync.
- Click the row of the synchronization connection you want to view.
The Status tab of the CIS Synchronization Connection page appears.
- Click View Error.
The Synchronization Connection Error Detail view of the CIS Synchronizations page Status tab appears.
- Click New Mapping Options.
The Synchronization Connection New Mapping Options view of the CIS Synchronizations Status tab appears.
- Complete the fields on the page, and click Save.
Synchronization Connection New Mapping Options, CIS Synchronizations Status tab - Fields.
Field
Description
Sync name
Synchronization connection name entered when the synchronization connection was created.
Choose new mapping option
- Assume no data—If mapping definitions for data items for which no mappings originally existed are synchronize later, the CIS software continues to ignore the previously unmapped data. For those data items, the CIS software processes only data that arrives subsequent to the mapping definitions.
- Replay transactions—When a new mapping definition arrives, the CIS software replays all transactions that contain the control path in the new mapping. If the CIS software finds any new mappings, it inserts the data in the appropriate Clintrial database column.
Temporarily apply to continuous mappings?
Start sync?
- Yes—Start the synchronization immediately.
- No—Do not start the synchronization immediately. When this option is selected, the synchronization either runs when scheduled or if a user manually runs the synchronization.
