Viewing general information about a synchronization connection
You can view general information about the Clintrial and InForm computers for the selected synchronization. The General tab is only for viewing information. You cannot change information in this tab after the synchronization is created.
- Select Admin > CIS Sync.
- Click the row of the synchronization connection you want to view.
The Status tab of the CIS Synchronization Connection page appears.
- Select General.
The General tab of the CIS Synchronizations Connection page appears.
General tab of the CIS Synchronizations Connection page - Fields
Field
Description
Sync name
Synchronization connection name entered when the synchronization connection was created.
CIS Metadata Locale
Specifies the language to use when synchronizing the trial.
Clintrial
Clintrial information about the synchronization connection definition.
Machine
URL of the Clintrial Adapter.
Instance
Clintrial database instance for the synchronization.
Protocol
Clintrial protocol to which the synchronization connection transfers data.
Metadata Only
- True—Only metadata is included in the synchronization.
- False—Metadata and clinical data are included in the synchronization.
Auto-generate Codelist
- True—CIS automatically creates a Clintrial codelist for each InForm radio group or pulldown control mapped to a Clintrial item.
- False—CIS does not create Clintrial codelists.
InForm
InForm information about the synchronization connection definition.
Machine
URL of the location of the InForm Adapter.
Trial
Name of the InForm trial.
Mapping
Name of the mapping definition used for the synchronization.
