Overview of CIS Administration
The CIS Administration application enables you to administer your CIS environment from a central application. Use CIS Administration to:
- Manage synchronization connections. A synchronization connection defines a communication path between an InForm study database and a Clintrial database. By using the CIS synchronization features of CIS Administration, you can:
- Define synchronization connections and standard synchronization schedules.
- Initiate synchronization and monitor synchronization status and history.
- Create study books for a protocol.
- Enable notifications in the case of a synchronization error.
- Edit failed transactions from InForm software to the Clintrial software to enable processing to continue.
- Manage CIS user rights and roles.
- Define and update the CIS environment, including:
- Database instances for the CIS synchronization.
- Adapter components of CIS.
- Load-balanced computers.
- Environment configuration settings.
