Logging on to the CIS Administration application
To start the CIS Administration application, you use the Clintrial Integration Solution logon page. Before you can log on, obtain the URL for the logon page.
- Type the URL for the CIS Administration application into your browser.
- Type your user name and password.
The CIS Administration home page appears.
Note: The CIS product provides an initial logon with a user name of CISAdmin and a password of CISAdmin#1. Use these logon credentials for the initial logon. You should change your password after you initially log on.
CIS system administrators can change a user password and can set an interval after which a user password expires. If your password has been changed by an administrator or has expired, you must change the password the next time you log on to the CIS Administration application.
For more information, see Changing your user password.
