Enabling and disabling auto-refresh of a CIS Synchronization Adapter
You can enable or disable the auto-refresh option for adapters. If you enable the option, the page automatically refreshes based on the value entered for the auto-refresh rate.
For more information, see Setting a home page and auto-refresh rate.
Note: Depending on the auto-refresh rate and your environment, selecting Auto-refresh might impact the performance of the application.
- Select Admin > CIS Sync.
- To enable or disable auto refresh, select one of the following:
- To automatically refresh the page at the configured rate, select Auto-refresh.
- To specify that the page refreshes manually, deselect Auto-refresh (the default).
- Click Save.
