Sorting the synchronization connection list
You can change how the synchronization connections appear in the table by clicking each column heading to sort the column. For example, if you click the column heading CIS Sync name, the sort order switches between ascending or descending alphabetical order.
- Select Admin > CIS Sync.
- Click the column heading you want to use to sort the table.
The columns in the table sort based on your selection.
