Sync Connections tab of the CIS Synchronization Adapter page—Fields
Field |
Description |
Auto-refresh |
Create New Sync Connection |
Click to display the first page of the CIS Synchronization Connection Wizard and start to create a new synchronization connection. |
Status (filter) |
List of possible synchronization connection statuses. To display only synchronization connections in a specific status, select the status from the drop-down list. Possible status filters are:
The columns of the synchronization connection table display information about each synchronization connection. |
CIS Sync Name |
Name of the synchronization. This is the name entered when the synchronization connection was created. |
Last Sync Start (UTC) |
Last time the synchronization started. Synchronization schedule time is stored as Universal Coordinated Time (UTC) time. |
Last Sync Duration (min) |
Number of minutes and seconds it took to complete the synchronization. |
Next Sync Start |
Next time the synchronization is scheduled to start. Synchronization schedule time is stored as Universal Coordinated Time (UTC) time. |
Enabled state |
Note: If a synchronization is disabled, you can start the synchronization manually by clicking Sync Now. |
Status (synchronization connection) |
Run status of the synchronization. A synchronization can have the following status:
