Adding a new email address
- Select Admin > CIS Sync.
- Select Notifications.
The Notifications tab of the CIS Synchronization Adapter page appears.
- In the New email address field, type the email address.
Note: The address you specify must be a valid email address that has been defined in your email system. The CIS Administration does not prevent you from entering and saving an email address that contains spaces and might not be treated as a single entity. To specify an email address that contains spaces, enclose the email address in double quotes.
- Click Add Address.
The new address appears in the list of email addresses.
Note: By default, a new email address is enabled to receive messages. To change the enabled setting, see Editing an email address.
