Editing an email address
- Select Admin > CIS Sync.
- Select Notifications.
The Notifications tab of the CIS Synchronization Adapter page appears.
- In the Synchronization Failure Notifications table, click Edit next to the email address you want to change.
The page becomes enabled.
- In the Email Address field, type the new address.
Note: The address you specify must be a valid email address that has been defined in your email system. The CIS Administration does not prevent you from entering and saving an email address that contains spaces and might not be treated as a single entity. To specify an email address that contains spaces, enclose the email address in double quotes.
- In the Enabled column, select Yes or No from the drop-down list to enable or disable the address.
- Click Update.
