Editing a Clintrial database instance
- Select Admin > CIS Sync.
- Select Database Settings.
The Database Settings tab of the CIS Synchronization Adapter page appears.
- In the Clintrial Database Instance table, click Edit next to the database instance you want to change.
The Instance, CISUSER Password, and Open Query State fields are enabled.
- In the Instance field, type a new tnsname for the instance.
- In the CISUSER Password field, type a new password.
Important: If you want to change this password, you must first change the Clintrial instance password for Oracle. What you specify for the CISUSER password must be the same as the Oracle password for the Clintrial instance.
- From the Open Query State drop-down list, select the Clintrial discrepancy status that corresponds to the InForm open Query status.
- Click Update.
