Removing a reference to a Clintrial database instance
- Select Admin > CIS Sync.
- Select Database Settings.
The Database Settings tab of the CIS Synchronization Adapter page appears.
- In the Clintrial Database Instances table, click Remove next to the instance for which you want to remove the reference.
A confirmation page appears.
- Click Proceed with Deletion.
Note: This action removes the reference to the instance. It does not remove the actual instance.
