Clintrial database
The Clintrial server in a CIS environment hosts a database of clinical data. Site personnel, monitors, data managers, and project managers use the Clintrial client modules to:
- Enter, update, verify, and validate paper-based clinical data.
- Import clinical data in batch mode.
- Analyze and archive studies.
Additionally, if an integrated study is set up to use Clintrial rules and derivations to validate EDC data, those rules and derivations usually run automatically against data synchronized from an InForm study. Rules and derivations are not run automatically when:
- There are cross-panel dependencies in rules scripts. Rules in the Clintrial are attached to one panel and there is no way of determining (before a rule generates a query) that rules should run when data on a different panel changes.
- Rules are changed.
In these situations, you should run manual validation.
Queries generated in the Clintrial software by validation failure synchronize back to the InForm study for resolution.
