Important data structures in the Clintrial database
The Clintrial database for a specific protocol stores data used in integrated studies in the following tables. For full descriptions of data structures in the Clintrial database, refer to the Clintrial Reference Guide.
Data |
Tables |
Clinical data |
UPDATE, DATA, and AUDIT clinical data tables When a panel defining a set of clinical data items is installed, the Clintrial software creates one of each of these tables. The name of the table is in the format panelname_tabletype, for example, DMG_DATA.
Clintrial discrepancy data |
VCT tables These tables, VCT_ERRORITEM_UPDATE and VCT_ERRORSTATUS_UPDATE, are copied from the CTVRESOLVEREF protocol into each protocol that you set up as a Resolve protocol. These tables track items that are associated with a discrepancy. |
Error data |
ERRORLOG table This table stores information about errors that occur during screening, validation, merging, and global change or deletion. |
Flag and note data |
TAGS tables This table stores information about flags and notes that are attached to clinical data. |
EDC protocol management data |
INF_ tables When CIS synchronizes a protocol used for EDC data to Clintrial software, it creates a set of tables to hold information required for processing the EDC data. These tables hold:
